The Autodesk blog "Inside the Factory" is asking about the Press and Drag option. Using this software for as long as I have I'm quite unhappy when the option is off. Maybe it's minor or strange, and to some irksome or even dangerous, but I'm very used to and happy to use it. So far the comments on their post seem to be running in favor of removing or "blunting" it somehow. According to one comment, I'm nuts for using or liking it.
The only time I get frustrated with it is with linked files. Revit's odd preference for "seeing" and therefore selecting linked elements over the native elements is something that ought to be fixed instead. Removing the Press and Drag feature should not come as a result of other issues.
I find it interesting that people who normally count clicks are "happy" to add more clicks for this item. I use press and drag for so many things, dimensions, text, tags, equipment, duct/pipe runs, walls, doors/windows, viewports on sheets, practically everything at some point. When things need to be precise it isn't the correct approach but so much of what we do during design and documentation can be adjusted more readily with it on.
If people don't want to use it, that's what the check box is for and it can be preset to "off" via the Revit.ini file already. Don't like it, don't use it, please don't make my choice for me.
- My vote is leave "my" Press and Drag alone.
