Share information from family with Tag - How?
    At present i have a shelving unit with 9 options being chosen by using Choose Model = 1
    Now, I also want the option to show as a generic label tag on the model, can this be done as the shared parameter is a yes/no.
    Any ideas? Without having to manually type in the text for the model type in an instance parameter?
    Creating BIM models from highly accurate 3D laser scan point clouds.
    Plowman Craven
    If I'm reading this correctly and understanding you, it seems you may be overthinking this. Why can't the user choose the model type via a Family Type (which controls the parameters)? I will need to verify, but I think there may be a label by default that pulls the family type name. If not you can make it a shared type parameter.
