Consistency Checks warning message
    Have you guys ever get similar warning "Detected physical connection between Structural Elements, but did not detect Analytical intersection" when running Consistency Checks?
    I made a very simple model (columns-beam frame) to test some of the commands. Analytical lines were connected and in my opining analytical model was consistent. I have also checked some old models I made and this warning is always displayed. Do you have any clue, what is then the error about?
    Thanks!
    What version of Revit are you using?
    Erik Snell, P.E.
    Factory Worker (Principal User Experience Designer)
    I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
      It is 2012 version.
        I'm not seeing this message. This message is intended to inform you when the analytical model has been adjusted manually so that it actually connects to a different element than the physical. Can you post your sample model?
        Erik Snell, P.E.
          Hi, please find the model in the attachment. It is the same model like in the case of support check warnings.
          In this simple model I left analytical adjustment set to Auto-detect and I did not adjust anything manually.
          Thanks for the interest!
