I'm pretty sure I've had this problem before, but I can't, for the life of me remember A: how it happens or B: how I fixed it.
So we are working on a large 6 story building with thousands of plumbing fittings (as one might expect) and as we've added more devices to the model, one of my colleges claims that "weird things" have been happening to his sheets. I find this dubious, and he's had help from a couple novice users... so my hunch is with user error. Until we found that some of the plumbing fittings ended up on a sheet workset!
But it get's worse. Even after manipulating the View Range, adjusting it multiple times, we're no longer able to select the fittings by using a selection rectangle. Picking them individually seems to work, but trying to select them all does not.
Anyway. It's a shot in the dark, but if any of you have had this strange problem happen before, help a dude out.
