I have a nested component that looks like linework is missing in a elevation view. I use symbolic linework in a plan view only, so what you see is geometry. The workflow I used:
1. Create a soild extrusion in plan with filleted corners.
2. Create a void sweep by picking 3D edges (lines and arcs) of the top plane of the extrusion for the path and creating a profile.
Could the void sweep cause the visual anomaly?
MEP2010
MEP2010
