Is it better to place a revision cloud on a sheet or on a view within a sheet? Is there any advantage/disadvantage of doing one over the other?
Revision Clouds
I have debated this issue as well,
a) if you place them on a sheet, they are easier to revise since you don't have to activate the view to select the revision. (less clicks)
b) if you place them on a view, if you move a view in a sheet , the revision goes along for the ride. (no worry of forgetting to move the revision)
Originally posted by dzatto View PostI'd say the view. lol You have to revise the view drawing itself, right? You don't actually do anything on a sheet except plot it IMO.
So invariably, there is no one way to do these things. I'm a sheet clouder...
Well, the sheet of course, which has the revised view on it. If you delete a wall or move a door, you don't do it on the sheet, you have to revise the view, right? Maybe I'm thinking of this wrong. The view just seems to make sense to me unless, as B Arch stated, you are deleting an entire view. Then you just cloud where it used to be, which is on the sheet.
Hell, just get some crayons and cloud the drawings by hand. Problem solved.:thumbsup:Dan
Sheets clouder.
It's easier and as gdoherty states: these are the ones send to the GC. So, I don't care if the view/model changes. I want to know what happens on the sheet.
Another brain teaser: do you place a revision cloud for a change in the model that isn't issued on a sheet yet?Martijn de Riet
I'm still learning about revision clouds, revision tags, and revision schedules. When I create a revision in the Sheet Issues/Revisions dialog, then cloud...February 3, 2011, 12:14 AM
I want to change some info on sheet information, but they greyed out. ( like current date info )
How can i modify them?
...June 7, 2017, 12:23 PM -
I have attached a picture that may explain it better then writing out the issue.to put it simply I have El and VVS and I have 1 revision on VVS and 3...
Channel: MEP - General
September 2, 2012, 08:21 PM -
I am having trouble with Revisions. It seems like whether you choose "Per Project" or "Per Sheet" it only displays the revision letter...October 8, 2013, 08:44 PM
I'm trying to remove a revision on one of my sheets but it is greyed out and cannot be edited. The revision is shown as cloud and tag but i've checked...March 23, 2016, 04:51 PM
