I almost always let the detail components handle the representations. Once in a while I would create a modeled connection for a 3D detail but still didn't model the holes in the steel.
No holes, not since the "cut with void" option in 2012 became available. I do model them from time to time (just for the fun of it...) but putting them in the beam is way too complicated (tried this once and stopped after day or two of :banghead. So I made parametric families with all plates, bolts and nots in them and place that in the project. Then create a Model Group and presto: done.
I tried with a bolt that has a void, attach command or cut command were without effect on the beam; but it works on a floor. so the problem should be with the beam...
I changed the material type, does nothing...
I thought it doesn't work, Ben what is your workflow please?
Julien "Au royaume des aveugles, les borgnes sont mal vus!"
P. DAC Follow me on Twitter @Jbenoit44 - Blog: http://aecuandme.wordpress.com/
Is it possible to add detail component into beams, to show detail in sections automaticly? Regarding profiles and detail components it works great, but...
I made a fairly complex baseplate and anchor bolt family that works pretty well for generating a schedule but I would like to take it one step farther....
How do you organize your detail components? I have thought up a couple systems, but they will all get shot the second you load an OOTB family in. Maintaining...
I'm struggling with the concept of using detail components and hope that someone here can set me straight. I do precast drawings, I've got the building...
This may be a question already asked somewhere, but I can't find a good answer. So...we are staring to add some detail to our first Revit project. When...
