What Revit Wants: Old School Simpler Railings without Baluster Placement dialog box
    Did you know that there is a different style of Railing description? This style does NOT have a 'Baluster Placement' dialog box. The only Baluster settings in this form of Railing are essentially to select a Baluster family and set a separation (see image).
    If you want to use this simpler type of railing definition, you can still download a sample file from Autodesk that includes this older method.
    Link to download the file here.
    Sample file index page:
    Revit Instruction & Help Samples\Revit Samples\Metric
    This issue is similar to using legacy mass forms in newer versions of Revit.
    Author of What Revit Wants
