Dumb question - I'm tagging my elevations and I am trying to get one tag to reference a view and the other to be a regular elevation. If I place the reference first I get a popup when I click the second one asking about what to reference or a new drafting view, but not a new elevation. If I place the elevation first I get no popup and can't figure out to make the second tag a reference... Is there a trick I'm missing somewhere?
Elevation Tags - Reference view & Elevation in one tag?
You'll need two elevation tags - one for the model elevation and one for the reference elevation.Greg McDowell Jr
about.me/GMcDowellJr
For what it is worth, the key is that either ALL the elevations associated with a symbol must reference other views, or none of them do. Which kinda makes sense, because the minute one wall isn't identical, the chances the others also aren't, or won't remain, goes way up.
Also FWIW, I have moved away from Reference other View in general. Way too many times I have seen that used as a crutch in early DD to make the set look more complete, usually with teams or PMs that are new to Revit and feel like they are behind. Then, later in DD some of those spaces actually change, and yet the elevations are not updating because the innate value of Revit has been neutered. Maybe it gets caught in QA, but more often it is caught in CA. So for the most part I suggest people do live elevation views of all spaces, at least through DD. If all four walls of a space are truly identical at 50% CD or so then the views are consolidated.
To aid in doing DD cost estimates, there will be a general note that says "Refer to such and such elevations for typical classroom conditions." Every elevation is included live, only one is fully detailed and noted. Honestly, I think you could take that all the way to construction but there is always resistance along the lines of "we have never done that", which is just a crock, and also "that wastes a lot of paper", which is more valid. But in the final accounting, I think we waste a LOT more paper including the finish plans in every set, even the one used by the steel framer 18 months before the finishes go in.
GordonLast edited by Gordon Price; January 10, 2012, 07:28 PM.
I have created a small callout view of our larger plan and am looking to show elevation tags that reference larger elevation views. The issue here is...August 4, 2015, 06:31 PM
I've been creating site elevations on A0 sized sheets. each sheet has 3 elevations, and a little key plan of where the elevations are located for that...June 16, 2014, 10:49 PM
I've got a multi storey house where the upper floor is offset, it would really sit on the sheet better if I could move the elevation markers in the upper...August 7, 2012, 10:38 AM
I am trying to reference a view for interior elevation to another sheet. I am using Revit standard interior elevation tag. When I click on the...February 27, 2019, 06:07 PM -
Platform is Revit Architecture 2011.
Project is a multistory building.
The problem is: Create interior elevation on the...October 19, 2011, 07:19 PM
