Profile Problem
    Profile Problem
    I have made an angle profile to sweep it across the edge of my roof as the edge angle. All is good, or so I thought.
    It went in fine, aorund all three edges - the roof is sloping, two sides the angle is flat and one side it is sloping. when I cut a section on the sloping side, for some reason I have an extra line.
    I would say it was becasue of the slope - but the plate (which is also a profile that I created a sweep out of) and the beam are sloping and they do not have any extra lines.
    What could be wrong with my profile? I have attached images.
    Yep - It's me Again, and Again, and Again.......
    It's because your "Far clip offset" is farther along the angle. Set it to be 1/256". See attached.
    Adam Hutchinson
    Engineer in Training
    Integrus Architecture, P.S.
