Hey guys!
First of all hey to everybody reading, cause I'm new here and happy new year!
The reason for my post is, because I am having some issue with placing a model component. I have steel HBE columns, covered in 2 layers of fireboard, within a wall construction. I have used the Voide extrusion to exclude the column construction out of the wall, which works perfectly if the wall is without windows, but when I put windows in the wall, I cannot uncut the geometry of the column + fire board construction out of the wall. It just does not work. I am using a normal wall, which I have modified and default windows as well. I hope somebody knows what goes wrong, because I totally dislike the outlook of my floor plans, without this void extrusion, also of course the construction is not done correctly...
Thank you in advance and all the best!
Best regards,
Yordan
Best regards,
Yordan
