stair: balusters between 2 rails - one below the steps
    I am trying to create a railing where the balusters start frm a railing running below the steps (as the yellow balusters on the picture). I created a lower raining and defined it as a basis for the balusters. It works fine for horizontal railings but not on the stairs... Do you have any suggestions how to handle this?
    Thanks a lot!
    You might need to modify the baluster family to provide a bottom offset parameter and associated ref planes and geometry changes and then change that parameter within the family rather than trying to use the system family settings to get a bottom offset.
    Michael
    Canberra, Australia
