Circular Column
    Circular Column
    hi, i want to add a shared parameter on the diameter of the circular column... but when i flex it, there is an error called remove constraint.. does anyone know how to constraint the diameter of a circular extrusion? thanks..
    draw a radius dimension and add a parameter to it. You may have to do it in sketch mode. Since Revit doesn't allow a diameter dimension, only a radius one, you have 2 choices:
    1. Leave it as a radius and do the math in your head.
    2. Create a separate parameter with a formula. Basically, call one radius and apply that to the radius dimension, call one diameter with a formula 2*radius.
    Dan
