Hi, i have error when joining roof although i follow the right process , What is the wrong ?
can not join roof (error) ?!
The different eave heights shouldn't matter... But yah, unless the two roofs are in different phases, you could attempt to make it as a single roof, even though, I'm pretty certain that you'd get a odd connection, where the different eave heights meet up.
Post a stripped down version of the project, if you haven't solved it by now.Klaus Munkholm
I made a roof with a roof cricket made up of two roofs. The main roof is a standard sloped roof that slopes down to the roof cricket roof which I made...May 20, 2020, 05:36 PM
Hello,
I have been trying to create a slightly complex roof, but keep getting the following error: Can't make footprint roof !!
As...January 29, 2015, 09:08 PM -
I've got an issue on a job where the two roofs refuse to join. The main roof was modified and after the change the dormer roof will not join. The only...March 20, 2013, 01:52 PM
Hello Everyone. I'm working on a roof that I wouldn't consider overly complicated, but I'm pulling my hair out trying to get something to work! I haven't...February 24, 2016, 09:25 PM
What is the best way to go about connecting the dormer roof to the main roof? (see attached)...February 28, 2017, 08:24 PM
Monumetric Footer In-screen
