Picking Walls from Level Below
    I am trying to copy some walls from level 1 so I can rotate them to another direction on the same level. When I try to copy using a regular window, the walls from the ground level are selected as well. How can I pick the walls just from level 1? It's almost like Revit does not recognize level 1 at all.
    Thanks!
    Check your view range. If your Primary Range-Bottom is set to the level below you'll be able to select items on that lower level.
    If you need to see your level below you can keep the Primary Range-Bottom to your current level and either use underlays or change the View Depth-Level to the level below. You control the lineweight/style of the level below when using the second method by changing the <Beyond> linestyle.
    Greg McDowell Jr
    about.me/GMcDowellJr
      That was it, thanks!
