Historically, Large Revit firms use a variety of parametric generic tools in the early stages of design before transitioning to Revit especially when the geometry of the project is complex. Once a project is moved to DD, CD a Revit model is build for documentation purposes while the facades and other complex structures are done in Digital project or Generative. Obviously the more traditional projects are done fully in Revit.
There was an interesting lecture given at AU, by Robert A.M. Stern Architects where they showed the Yale residential college project. While the aesthetics of the building is very traditional (bricks, orthogonal, classical ornaments) they used Digital Projects to model the windows and doors, because Revit couldn't handle the storage of large amount of unique windows in the project. The file size increased exponentially when more details ware added to the window families. The DP parametics windows where imported as static clean 3d CAD objects in Revit which decreases the file size.
Has anyone have any experience in using DP or any other parametric modeller to create families for Revit? What is your work flow?
