Default Position of Door Tags (or any tags for that matter):
    Hey Guys,
    Wondering if anyone knows of a way to "preset" the default position of a door tag. Seems to snap by default to the center of the door (geometry in the family), but it would be nice to have it automatically snap to the center of the door leaf...
    Originally posted by Jj Mac View Post
    Hey Guys,
    how would the tag know which leaf to center in if you have a pair of doors?
      Tags default to the intersection of origin reference planes.
      Greg McDowell Jr
      about.me/GMcDowellJr
        If it's a nested components with 2 leafs in it, it needs to center between the leafs.
        If both leafs are nested separately, they need to be tagged separately...
        But I think the OP means that the placement of tags should follow the intersection of the refplanes labeled "Defines Origin"...
          There are two Reference Plane in the Door Family (and the Tag family, for that matter) that have the "Defines Origin" property set to true.
          The intersection of those two Planes defines where the Tag goes - kind of like how a Room Tags goes to the "X" of a Room.
          You can't really mess with those Planes, though, because they define other things like how the Door family flips.
          There's been a long-standing Wish-List item to allow us to specify where aTag would go, but - no action on that yet.
          Dave Plumb
          BWBR Architects; St Paul, MN
            maybe? I think that this is what the OP meant
              Well, to do that, you need to make the door leafs two separate families with the center ref plane defining origin... Then tag the door leaf, which is quite doable IF:
              create a custom shared text parameter. Link it to the parent ootb Mark parameter. The custom parameter now mimics the Mark parameter from the parent door family.
              create a door tag which reads the custom parameter and tag the leaf instead of the entire door.
              Done
                Thanks for all the replies everyone,
                This is what I was affraid of - that it defaulted to the origin and that screwing around with that, would defiantly not be a good thing. This was more of a do-dilligence question anyway, so...
                I think we defianlty need to have the ablilty to definte a seperate "tag origin" in all families. And also a leader start origin in all annotation families. That would be the cat's wiskers.
                Thanks again guys!
                Happy Holidays!
