Structure generator requires mesh elements.
    Has anyone tried out the Sturcture Generator from Autodesk Labs?
    Autodesk Labs Utilities Structure Generator for Revit
    It converts mesh elements into structural elements. However, as I recall, Revit cannot create mesh objects.I'm probably doing something wrong.
    Hi Andrew, I tried it, it works great.
    to create a mesh, you have to divide the surface, rectangular. then use SG.
    some help is provided here.
    Julien
    P. DAC
      I only divided the surface, but didn't apply a rectangular pattern, which explains why it didn't create the structural members.
      Thanks
        Hello, can someone provide me the structure generator.
        I am a student does not have access to the page Autodesk Labs.
        Thanks.
          ccjoes
          Sign up to it, its free
          Dwane
            Well I have been attempting to use this tool, and I am following the right process of dividing the surface then applying the pattern, however I still get "No mesh elements found". I am doing an in place mass does it not work with in places masses?
