It would be nice if the gang at the factory would add some re-sizing magic to this dialog too!?! The Tag All dialog can be a bit hard to deal with the type name when some company naming conventions result in long names. There's only so much room to adjust the column widths within the fixed frame of the dialog. Seems like such a minor kind of finesse?
In the past I wrote about a free utility (that David Kingham found) called Resize Enable that permits some "hacking" overrides of the dialog sizing. I just downloaded it and ran the app again tonight. It does work to allow for stretching this dialog though it gives no visual clues that it will work. You just have to trust...click and drag to see if it does and it does (true for me using Win7/64)
