Shared Parameters and DB Link
    I have created shared parameters using the DB Link add-in and have exported Revit data to a SQL database.
    I then created shared parameters using the Shared Parameter tool from the "Manage" tab. I then assigned the shared parameters to a type within a family under mechanical equipment. After populating an elements shared parameter fields in the "Type Properties Form" I run the export again using the DB Link add-in.
    Does anyone know if the DB Link tool will export data related to shared parameters stored in the type properties of an element know as RTU-06?
    Thanks
    Just take a look at the tables of the categories you assign that SP.
    It should show up as a column in the tables.
    Gonçalo Feio
      I am trying to find data related to the Family Types - not categories like Mechanical.
      I am building family types within the mechanical category and want to find stored data related to shared parameters added to the family type for an element that is assinged to the family type.
