Hi, I'm trying to do my first project that is on a sloped surface. I can not really figure out how to adjust topography elevations. Any hits, tips, tricks, or any info on how to do topo is helpful. Thanks
Topo problems
What are you using to create your Topo? The actual topo function? Cause then when you edit your toposurface, you'll see all these black squares defining the topo. Select a square (or a bunch of them) and in the Properties you can change the Elevation.Martijn de Riet
I've just noticed when I've changed view that part of my topography has been deleted! I initially tried to use sub region to change the surface...April 27, 2014, 04:15 PM -
Hi guys,
We had a survey done for a new house site and the surveyor hasn't quite picked up enough terrain which is resulting in 3/4 of the...November 20, 2019, 03:11 AM -
I am looking at grading a topo surface. I am not sure its possible. I want to grade certain area's of a topo to certain ratios. I.e 1:3 over a certain...July 13, 2021, 02:19 PM
I am trying, very unsuccessfully, to get either A. 3D poly lines or B. AECC_TIN_SURFAC, out of AutoCAD and into a Revit toposurface. The catch22 here...July 16, 2013, 06:15 PM
hi all!
i'm having a problem with building pads and topo. when i placed my building pad, there is something crazy happening with the topo!...June 6, 2012, 08:29 PM
