Here is a nice little tip for those who might collaborate in an imperial/metric environment
Say you work in imperial units and want to move a wall in a project and the and the designer is uses the metric system and he tells you to make the wall 3.2m from the end wall.
You could a: Do the math yourself and input the dimension, or
b: Let Revit do the dirty work for you
You just have to append:
m for meter
cm for centimeter
etc.
Ex:
Revit will take the value you input and converted to the system units.
This also works the other way around. Just add
ft for feet
in for inch
etc.
Hope you find this useful
m for meter
cm for centimeter
etc.
Ex:
ft for feet
in for inch
etc.
