Yep, use a really small circle for the top, larger circle for th bottom, and then push the top circle to the side before or after creating the form. The point of the cone won't be a true point anyway when built.
I wonder if there is any way to do this by using Conceptual Mass ?
I think you are still going to have to create it with 2 circles. the top one can be pretty samll so it basically looks like a cone. It just does not converge to a singular point. Here is an example one I did with a small radius circle at the top.
Use a revolve in either the massing or generic model family. Draw the rotation axis at an angle and use a void to cut the bottom. This way you'll have a real cone with a point. It think it'stime that Autodesk ads a very necessary cap function to Revit.
I am trying to control angles of two reference points which are created at different levels, but when I create a solid form, the point on the level above...
hello, ive been trying to select the top of a blend as the work plane but i cannot do it. when i click 'set', im able to pick the top portion of the blend...
