Cant see my section line
    Section line only showing on few plans :basement and floor plan, not the other upper ones. I did some adjustments with names and types on a section properties before.. Now i cant find section line in upper levels plans.
    VV does not hide.
    First time it happened to me;]
    Thanks in advance
    It sounds like the extents of your section line doesn't cross into the upper levels. Open your section and make sure the crop view goes up far enough to cross the upper most level's cut plane.
    Dan
