I'm working off of a model created by another user and there are existing reference planes that fixtures are hosted to. I cannot seem to view these reference planes in section. I have created new reference planes that i can see/move/edit in section, but now that i need to move the existing reference planes i am unable to do so. I can still host fixtures to it, they appear when i edit the workplane of a fixture, but i cant see them in order to move them. Any ideas how to make these planes visible/editable?
Reference Plane Visibility
Go into a 3D view, make sure there is nothing croping anything in your 3D view. Set your work plane to the troubled RP and click Show. This will show you the extents of the RP. Verify that the RP does in fact cut thru the section you are having trouble with. If it does cut thru the troubled section view... I am stumped... But more then likely the RP's extents are not being cut by your section.-Alex Cunningham
Originally posted by jana.honkova View Postmake sure your section line is PERPENDICULAR to all your reference planes.
I have only just figured this out. It has been driving me mental.
Good luck .-)
Ha..typical.
I never use ref planes (Except in families), they clutter up the model.
I dont even use sections any more, unless they are a detail to go on a sheet, for the same reason.
Strangely (Because the industry is fixated on 2D?) they have tried hard to make 3D inaccessible in revit despite it being a 3D environment. But if you figure out what works you can model almost everything in 3D views and zip around in your model using the 'BX' auto 3D view.
You can set your workplane to any existing surface in the 3D view and also use that to rotate things vertically.Last edited by josephpeel; March 15, 2018, 05:42 PM."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
You can set your workplane to any existing surface in the 3D view and also use that to rotate things vertically.I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View PostHi Joseph, out of curiosity, what is a 'BX' auto 3D view??
Still a welcome addition to Revit though.
Ps 'BX' is the default Revit keyboard shortcutLast edited by elton williams; March 15, 2018, 10:04 PM.There are no stupid questions, only stupid people
Hello,
I'm a Sparky and like many of my colleagues, we host our light fixtures to reference planes. Well, sure enough, we had a co-worker...October 22, 2014, 08:15 PM -
I am designing a scaffold that is on a slope. I've used a reference plane to associate all the elements and families to the correct inclement....April 13, 2017, 08:37 AM -
Hello
Is it possible in Revit to set up Section View in the way that it's associated to a reference plane, so that, by default, any object...November 18, 2021, 09:46 AM -
I have created some reference planes in a plan view, named them, and used "maximise to 3D extents" on them. When I go to another plan view I...August 22, 2012, 07:45 AM
Perhaps I am missing something, but is there a way to filter a reference plane? I usually do not use them, but most people at my company just love to...January 17, 2011, 01:15 PM
