How do you set up arrays less than 2
    I am creating a family for steel soldiers, the soldiers come in varying lengths 675, 450mm etc.
    In the soldiers are holes which I have created with void extrusion and array.
    The 675 soldier works fine however the 450 soldier I get the error msg No of square holes has an invalid value.
    I have set up the parameter No of square holes (length/225)-1
    Does anyone know of a formula for arrays less than 2 of how to solve this problem?
    Revit 2019 user
    Arrays can't be less than 2. I generally create instances like that by cloning out the family. One family has the single instance and the other has the array.
    Edit:::
    I suppose you could add in an if() statement for if the array so that if the value goes below 2, make it 2 but have a length parameter move the void array out of the model and slide another void into its spot with another length parameter to cover the single instance.
      Andrew's got it - it's all about conditional statements controlling "rule" parameters (either lengths or, as I prefer, visibility).
      Dan (unintionally I'm sure) opened a can of worms on the subject HERE
      And welcome to the forum BTW! :thumbsup:
        n (integer parameter driving the array)=if(formula to determine n < 2, 2, formula to determine n)
        the rest is redundancy and visibility parameters.
        see example. Click image for larger version
        There must be a better way...
        Ekko Nap
          Care to tell everyone that all this is done cause someone (not saying it's you) wants this perfect little insulation hatching....
          oops... :laugh:
          Seriously: I teach this example in my classes always. It's completely retarded to go through all that trouble but it's a nice excersize in family creation.
            oops... :laugh:
            Just wait till I get it to miter
            Still, as long as I'm doing details in 2D I do care about a clean look. Makes the drawing much more legible. Plus, it rotates!
            Final argument is the best though: unless I were to get very unfriendly, this will save me the time spent arguing against it.
            Ekko Nap
              Wait one second, Ekko are developing a line based component for insulation batting?!? :crazy:
                No, I am not. I was, last friday afternoon. Next time I can spare an hour or so, I'll get the mitering bit done.
                Ekko Nap
                  Yup, but he's not alone... Did you know this is always in the first 3 questions I get when I do a demo? "how do we draw a proper insulation". Like I said, completely retarded... Even worse: it's an official dutch (cad)drawing regulation. Needs to look like this. Personally, I think they should stick it... But that's just me. Once you are legally bound by contract to have your drawings follow the official standards you're screwed...
                  Nonetheless, I like my drawings to look nice and clean too. That's why I make a good habit not to sneeze on my screen :laugh:
                    Frustrating isn't it. Almost enough to just get it over with. Anyway, I think this was the first time I used formula's to drive formula's in a nested family. Has potential. Beware though: tangents are a pain in the [MdR regulation storage facility] when driving other formula's.
                    Ekko Nap
