Masked Annotation Symbol
    Is there any rhyme or reason as to why an Annoation Symbol with a masking region in it will hide the section line that is behind it sometimes and sometimes it doesn't? The masking region hides model geometry properly.
    It seems to be something along the lines of a "draw order" thing, as in when I place a new symbol it will hide the section line but existing ones don't. To bad draw order isn't applicable to annotations.
    Joshua Kohl
    Eastern Exterior Wall Systems, Inc
    www.eews.com
    It definitely has something to do with the order the objects where placed. I'd tell you to cut-and-paste that section marker but that might not be such a good idea if you've already got detail and annotation work in. Still, that's the only way I've found to correct this.
    Greg McDowell Jr
    about.me/GMcDowellJr
