Hello All
I am new to revit and using 2011. I have taken a couple of courses but most of what I have learned is self taught. I have been given the task of creating a small canopy that contains a tapered beam but on a sloped on the attached pdf. I have created a family for the tapered beam but I can't figure out how to get to slope. also as you will notice that there is a beam in the centre between the tapered sloped beams.
Can someone suggest the best way to go about achieving this. in the family i created, i started with a blend extrusion
Thanks in advance
Kevin
Thanks in advance
Kevin
