The View Range settings should be cutting Wall 1 for this plan. Wall 1's height is 5'6" There are no Element Overrides. Even Walls 2 & 3 display the same behavior, but once the wall height is moved beyond the 6' height level, it starts cutting...You can see the View Range settings, it doesn't make sense to the graphic output.
Orange is the Beyond line style
Green is Wall category VG Projection line
Red is Wall VG category Cut line
Any ideas? Hope the screenshot is clear to those trying to help figure it out.
-Kirk
-Kirk
