I have a wall that is joined to 5 other walls, and despite unjoining the wall from everything or cutting and re-pasting the wall it is still joined to the same other walls! Does "join" mean more than one thing in Revit?
un-unjoinable wall
Juan: I just confirmed that all walls are NOT dis-allowed to join. I guess there's joins for walls and joins for geometry, isn't there? I used the UNJOIN GEOMETRY tool, but didn't consider the automatic wall joins are not affected by the tool (the word "everything" in the bottom left screen corner instructions is misleading).
Thank you for your help. Can you think of other versions of join in Revit?
I have a problem with joining wall which is made of several layers, with concrete wall. In attachment is the picture of the problem. Does someone have...November 6, 2012, 10:39 AM
I've been working on a few projects lately (2013 - No Patches) where my plan views which once displayed my wall joins correctly, now do not. Sometimes...April 3, 2013, 10:58 AM
I am trying to construct a bay window/turret for a residential project but I am having a hard time getting the walls to join properly. I have tried using...February 24, 2017, 07:35 PM
I cannot get my walls to intersect. 3 walls come together at a somewhat odd connection. One is an arc, and the other 2 are straight lines that meet at...December 13, 2015, 02:16 PM
I created two wall sweeps (with a simple rectangular profile) on two seperate walls, and I would like them to join at the corner. The walls are checked...January 8, 2018, 04:53 PM
