is it possible to change the colour or material of a structural beam
changing colour of beam
Originally posted by renogreen View PostSure. Select the beam and in the properties box the Beam Material box will take you to the materials and you can change it to any color you want.
I'm Framing out a Residential Floor System with TJI Joists & Rimboards. The Easy part was creating a Beam System for my TJI array. What is surprising...
June 1, 2013, 12:22 AM -
Hay Everyone
Why cant i split a beam ? is there anything i have to do before ? :banghead:
Thnx for You-
March 26, 2012, 12:56 PM -
HI,
I need help
I use Autocad Structural Detaling and I have troubles with beam. I need to make a beam with differente sections (30x60...-
January 8, 2012, 03:57 PM -
if i have a beam meet a wall then a part of the beam stop and a part is continue, this beam with type mark B6 so how can i do that without doing another...
August 5, 2014, 06:57 AM -
Hey guys. Could you help me?
I´m trying use a beam system to define a roof structure.
When i change the beam direction the beam doesnt go...-
September 23, 2014, 03:46 PM -
