i have a strange case in which 2+ lighting fixtures not in the same position still generate above warning message, i cannot figure out the reason yet, anyone?
warning message of "There are identical instances in the same place ..."
thanks all, but none of those you guys mentioned above.
i just did a little test using cut / paste same place, the exact same lighting devices w/o warning are OK, but the ones w/ warning will generate serious error message.
i assume it's internal data error even though i don't know what causes such behavior, i'll re-insert these lighting devices w/ warnings, seems i don't have much choice, do i?
by the way, it's not OOTB family.
edit: after i move away & back of these lighting devices, warning messages no longer exist, so i "fixed" problem even though i don't have slight idea of what's going on.Last edited by Ning Zhou; December 8, 2011, 03:53 PM.
I would however be inclined to do a save as and keep an extra backup file at this point. just sayin...Martijn de Riet
Using rvt 14'
I cannot for the life of me find a emergency lighting family that is not wall hosted pre 11' or what ever is it (no longer...-
Channel: MEP - General
January 5, 2015, 11:54 AM -
What is best practice for light fitting creation please?
1. If my light fitting comprised of two or more identical shades, I would like...-
August 21, 2014, 01:01 AM -
I originally wrote the following on the HOK BIM Solutions blog and have since received some additional comments/observations that I would like to add...
Channel: Blog Feeds
March 23, 2014, 09:15 PM -
I have two adjacent ceilings (one flat and one sloped). I add a light fixture to one ceiling, then use "create similar" to create another instance...February 14, 2014, 08:04 PM
i created line based lighting fixture for both linear and curved cases, want to make light source follow that line or curve
1) Emit from Line Length...-
Channel: MEP - Family Creation
May 11, 2012, 09:04 PM -
