Dimension (shared parameter)
    hi, i have a beam dimension which is a shared parameter, "h" for height of the beam and "b" for width of the beam.. i want that the "b" will go up first than "h" so that when i do tagging, it will read the "b" first then "h".. what shall i do? tnx.
    Change the order of parameters in your Beam Tag.
    best regards
