I'm working on making construction documents and i have not figured out how to have a grid that stays on every sheet and refers to drawings. for example, an interior elevation tag would include where it lands on the grid (A5) and the sheet it lands on (I-501). Any thoughts?
grid lines attached to drawings and views
The Out Of The Box Elevation, Section, and Callout Tags all have that feature built in. In fact, it's one of most people's favorite things about Revit. Once you place a View on a Sheet and give it a number, everything stays updated.
I'm guessing you've got one of two problems:
1.) When you place and Elevation Tag, it doesn't have the Detail or the Sheet number on it. Those don't show up until you take that Elevation and drag it on to a Sheet. You have to enter the Detail number, but the Sheet is picked up from the Sheet Number.
2.) This is probably what you're really asking about. No, there is no method for Revit to figure out how your firm has your grids (which I would term modules) laid out and recognize that the lower left 3 inch square is module A5, and the next 3 inches to the right is B5.
You have to type the Detail number in yourself, and if you move an Elevation around on the Sheet, you have to change the number yourself.
But once you change it, it changes on every sheet that Elevation Tag shows up on.Dave Plumb
BWBR Architects; St Paul, MN
I have an interior elevation tag that has somehow lost it's sheet location. (see attached image). The interior elevation views are located on the sheets,...August 5, 2014, 09:13 PM
To improve legibility when working in views we like to have all sections not on sheets display as halftone. We'd like to extend this standard to elevations...May 7, 2018, 08:13 PM
I would like to create an elevation tag for my unit bathrooms and kitchens that group 2 or more elevations on the same Detail Number within the circle...November 11, 2013, 11:46 PM
Happy Friday!
I'm trying to reference a drafting view that I made and the section tag is referencing the sheet that I'm placing it on rather...September 21, 2012, 04:50 PM -
Hi all,
Apologies if this has been asked before.
Our office is currently transitioning from Auto CAD to Revit and we are struggling...June 3, 2016, 09:03 AM
