Hi guys, whenever I export to PDF alot of the lines seem quiet blurry, ive set it to raster processing and set the rasters to presentation, and replaced half tones with thin lines but the PDF's still seem quiet blurry and unprofessional, any idea whats wrong?
Export PDF
Originally posted by Alex Cunningham View PostDon't use Raster... set it to Vector and it will not be blurry at all. And it will make smaller PDF files.Martijn de Riet
Originally posted by mdradvies View PostOnly problem with that is that it won't work with shadows, rendered views, jpg's, and so on... Revit will automatically use raster in those cases.-Alex Cunningham
Originally posted by Alex Cunningham View PostIn those cases... wouldnt it be better to export to a Image file so you have better controls over the rendering? PDF isnt really something that you use for awesome pictures...
And a render / realistic 3D doesn't need to be extremely topnotch if it's going at a 10x20cm picture on a large sheet...Martijn de Riet
I know, I already applied that one a long time ago... Haven't had any problems with it for years (besides the fact that it needs way more RAM to print)
O, and setting your lineweights to thin lines for surface lines is also a good option. Works wonders...Martijn de Riet
I printed a couple camera views and when printing to a PDF (Bluebeam) there is some triangulation / faceting in several areas that does not appear if...January 19, 2015, 01:43 PM
My company has taken over a job by a previous engineering firm. They have some pre-existing PDF's that are superb quality and I just can't get it quite...May 17, 2012, 04:35 PM
Hello,
when I try to export or print my Revit file, there won't be an option for me to convert it into PDF.
What should I do?...April 25, 2015, 11:45 PM -
Hey all,
I have encountered an interesting issue.
I was asked to trace a sign (as the internet jpeg blown up didn't look...December 9, 2010, 03:31 AM -
How do you export plan views in pdf format for a clients review?October 23, 2012, 04:30 PM
