Baem edge
    Baem edge
    Hi guys, beam edge will appear as hidden lines in what case? when it is cut and set the exace view range? is it possible that i want my beam edge to appear as hidden lines alwas in plan view? even if the top face of the beam is the same level with the slab? pls see attachment.
    Yes, you can:
    1) Go to the plan view
    2) Visibility graphic overrides (press VV or VG)
    3) Highlight "Structural framing"
    4) Under "Projection/Surface", press "Override"
    5) Change the line to a dashed one
    I've made a small video:
    Change to dashed line - lucis29's library
    Revit Architecture 2013 Certified Professional
