hi guys, does anyone know how to model this kind of ramp? pls see attached image of the profile. take note that this ramp is a spiral ramp.
Ramp Best Trick
One possible solution is this:
Create a profile family for the section of the ramp. Then create a ramp with the ramp tool, setting up levels and slope, etc. Then create a model in place as a Swept Blend, creating the path by using "pick 3d edges" on one of the curved edges of the ramp. Load the profile correctly on both ends of the path. Finish the model in-place and then delete the original ramp. The profile can be modified to include the parapets, if necessary.Attached FilesFreelance BIM Provider at Autodesk Services Marketplace | Linkedin
Very nice trick! :thumbsup:
Although I wouldn't exactly delete the original, more make it not visible in views. Or really thin as a deck for the sweep under it. Just because when you use the pick line tool the sweep should update when changes are made to the ramp (right?). It would be easy to have the original ramp as a placeholder when some dude decides to change the level height with 100mm...Martijn de Riet
Rep
Hi Guys
I have a similar problem, but due to legislation I need a landing every 10 meters (for the disabled). I tried various methods but I still have this problem at the landings (see attached). The images should serve as an explanation. Basically the custom section's plane is not vertical. Can one manipulate that plane (profile 1 & 2)?
Any help would be appreciated.
Capture.JPGCapture2.JPGLast edited by judicatordex; April 22, 2013, 02:52 PM.
would be nice if we could have multiple profiles for a sweep...oh wait we can in the conceptual massing environment
either way the above mentioned methods would still work, just need a bit more forethought. if you created your ramps/landings in separate pieces. model one of each then copy/paste/elevate would be a simple (if brutish) way.There are no stupid questions, only stupid people
Hey Guys,
I have a curved ramp that goes from one level to another. I need to create the concrete walls that support the ramp on the bottom...September 9, 2013, 08:01 PM -
Hi i have ramp that leads to grage just first time face this in revit so i used ramp command in revit but it is not going right the ramp its depth to...January 6, 2012, 09:17 PM
hi every body. i have Revit strutural 2016 i tired to draw long and big ramp and same slop and continues ramp from floor to the next floor above....
April 7, 2016, 09:59 AM -
Do ramps not have an auto break like like the stairs do? I thought it did. Is there a way to add a cross slope to a ramp?October 9, 2012, 03:42 PM
Hi all,
Hopefully this is an easy question for someone who's dealt with this, but could someone walk me through on the best way to model...September 5, 2012, 07:29 PM
