I'm trying to build a computer for college to use Revit and a renderer like Twin Motion 2 or Octane. I was looking to send around $800 to build one that can handle big projects and do fats renderings. I would need to buy everything except teh monitor, mouse, keyboards, speakers. Anyone have any good recomendations for a computer for around that budget?
Good Computer Build for Revit & Renderer?
The common wisdom is that for revit you need the fastest CPU and max ram you can afford, (8 gig is OK, 12 is sweet) and for gpu rendering (Octane) the best NVidia Card you can afford. I am using a GTX460 and even though it is a pretty cheap low end card, it is still wickedly fast to render compared with CPU rendering.
That's the basic framework - everything else is leg work to find what you can buy in your area for the dollars you have available.Ian Kidston
http://allextensions.com.au
How does this build look?
CPU: Intel i7 2600k
MB: GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL11D-8GBXL
GPU: GeForce GTX 560
PSU: CORSAIR Enthusiast Series TX650 V2 650W
HDD: HITACHI 500GB
CD: Sony Optiarc 24X DVD Burner
CASE: NZXT Phantom PHAN-001WT
Total cost is $938 with free shipping and after discounts.
Its a little more than I want to spend but its an alright price. If I could drop it down another $100 in price that would be great.
I could switch the ram wwith the same one except with a DD3R of 1600 instead if that doesn't really mater.
http://www.newegg.com/Product/Produc..._-20231416-L0FLast edited by aprincipe; November 25, 2011, 08:49 AM.
Spec-wise, that's a great system for Revit.
If you want to save a few bucks, get the i7-2600 (without the k) instead... e.g. this one.
If you want to save a few bucks, get a P67 based MB instead... e.g. this one.
While faster RAM won't hurt, you won't see any practical performance benefits. For the i7-2600, you don't need RAM faster than 1333MHz... e.g. this one.
I would recommend you get a HDD with 6.0GB/s for better overall hard drive performance... e.g. this one.
Good luck!
So I've, apparently, a fairly meaty machine under my desk (a Dell Precision T7500 w/ Xeon 5680 @3.3Ghz + 48GB 2666Mhz DDR3 RAM + 1GB Quadro 2000 + 150GB...
Channel: Hardware and Infrastructure
June 12, 2012, 06:28 PM -
Hello,*
I'm finally replacing my old 2006 macbook pro with a new one, it still works tremendously but I ran out of hd, it only has 3gb...-
November 21, 2011, 12:59 PM -
Hello,
I am customizing a new PC, and I am with some doubts. I will apreciate a lot any help from you.
The machine is for modeling...-
July 2, 2016, 02:02 PM -
Hello from France,
To start I wish to thanks the administrator(s) for your great forum and all the member for thier contributions, you are...-
July 25, 2015, 05:59 PM -
I really need some help here, I bit the bullet and purchased a Z840 "HP Z840 Xeon E5-2650v3 2.3GHz 2133MHz 10 Core 2nd CPU 32GB Ram NVIDIA Quadro...
May 13, 2015, 04:09 AM -
