Applies to: - All Verticals
New Feature / Problem:
The ability to use the Linework tool on Schedules and Sheet Indexes on the sheet view.
In order to appease the folk that used Excel for scheduling and its ability to change the cell border lines, detail lines are added just to give more visual to a schedule. Such as adding a thick line below the Header text or to separate different groupings.
But if the schedule changes, one must go back to that sheet and modify the detail lines.
Workflow:
Add Schedule to sheet, adjust columns, select linework tool and modify the line below headers to match outline, maybe use <invisible> to remove grid lines in header.
Benefits:
No more detail lines that don't follow the schedule when it has been modified. More visually pleasing schedules and sheet indexes that make the Principles happy with their Revit purchase.
Attachment comments:
Workflow:
Benefits:
