hi all, i want to create a post tension beam as shown in the attached file. i know i can make it as a separate beams, but i want that that kind of beam as one family so that i can view it in the schedule as one. is it possible to make that one? take not the the length where the beam depth should stop is variable depending on the location of the PT Beam. is it possible that there is a drag icon something in the family so that we can only adjust through dragging? tnx guys.
Post Tension Beam -Depth Issue
Hi alexo4141, yup, datbis exactly wat i wanted to do. Wat i mean s, can u give me somehow a procedure on how to model that PT beam? I want that the lengths of the beam can be adjusted depending on the length of the span. For example, in my framing plan, i have a PT beam whose length is 12m. But, the 7m length is 500mm depth, the 3m length is 700mm depth and the remaining 2m is 500mm depth. So i will create a beam base on that family so that the schedule will detect only one beam instead of creating 3beams. But how about if i have another PT beam on the other side whose length is 15m and the depths are on different lengths? What shall i do, or create a parameter in my beam family, so dat my family is intellegent enough to handle dat different beam lengths and sizes situation. I hope it clarify this one. Tnx again.
Alright, just made it on the corner... (RST2012)
I really don't know if it's what you're looking for.
HTH
EDIT: In case you're interested, I also made a post tension beam with blend (which means that the height transition is progressive)Attached FilesLast edited by alexo4141; November 24, 2011, 01:51 PM.Alexandre Cantin
Hay Everyone
Why cant i split a beam ? is there anything i have to do before ? :banghead:
Thnx for You-
March 26, 2012, 12:56 PM -
Hi there guys, I'm new here and my main language isn't english, so I ask for a bit of patience
I'm having troubles with beam cutbacks....August 9, 2012, 02:29 AM -
I would like to add the length of all my beams to beam tag.
However, when i try to add it when editing the label for the tag, there is no Length...-
May 23, 2012, 11:13 AM -
Hi All,
Just wondering if anyone from a precast or anyone who could help will be very much appreciated!! would you model a pre-cast...-
October 14, 2015, 06:21 AM -
I'm new to revit and have a question,
how can I create beam like the attached JPG
thanks....-
November 8, 2012, 07:31 PM -
