as we all know ...in an architectural project usually there is a sheet (or sheets) with all the doors and windows types from the entire project illustrated annotated and detailed. so does anybody know any easy way in revit on collecting all your windows and doors (front views) in order to be able to keynote them, annotate them and have them side by side in one or two sheets? :crazy:
Is there any easy way to create a sheet with all windows & doors listed and shown?
Legends.
PS--and stop YELLING already!!Last edited by cliff collins; November 17, 2011, 07:21 PM.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
Yep. Create a legend. Then, under the annotate tab>detail panel>components you will see a new tool, Legend Component.
Select that, and you can pick any family and any view and insert it into the legend. Then annotate it accordingly.
:banghead: I just realized something, I can use these to do casework details! For instance, my cashier counter. I've been creating a floor plan callout and using elevation markers. This is so much cleaner.
Can I reference a legend view with a callout?Last edited by dzatto; November 17, 2011, 07:25 PM.Dan
Originally posted by dzatto View PostCan I reference a legend view with a callout?
You could however make a "blank" drafting view. Technically a drafting view has to create something, but it could be the legend title or something or maybe just some white text. Then you can place the legend onto the sheet where the drafting view is. Now a callout can be created that references the drafting view you have placed on the sheet. You will have to create a new viewport type that has no title mark so it can beassigned to either the legend view or the drafting view. Not perfect but it works ok.
In the attached image the Window legend title and the title mark are the drafting view. The windows are in an actual legend view.
window_legend.pngJeff Hanson
Sr. Subject Matter Expert
Legends suck, on MANY levels. I prefer actual Plan, RCP and Elevation views, off to the side of the "main model", using Design Options to manage visibility and schedule content. Schedules are used to facilitate making sure that the "Legend" views are correct, complete and nothing extraneous. The same procedure is used for Doors, Frames & Relites, Windows, Casework, Materials and even Mounting Heights. True curtain walls and storefronts are addressed with a Curtain Wall elevation type, which is filtered out of all documents views.
Using the same "view" on multiple sheets is done with Dependent Views. NOT elegant, but still far superior to Legends, which again, suck.
Gordon
Hello,
I placed a few windows in the legend. I remarked that the most windows are placed with the frontside, but a few pieces are placed...February 6, 2018, 10:41 PM -
Quick general query ... probably with a long answer.
What exactly do I use the legend function for?
Channel: MEP - General
July 22, 2011, 10:28 AM -
A. How can we include elevation and plan views of the windows with dimensions in the default auto-updated schedule of Revit?
B. If one project...September 30, 2017, 07:32 AM -
Hi, I am trying to create a demolition legend (something a bit like the attached drawing) to illustrate the different phases of a demolition job however...October 1, 2020, 06:04 AM
Legend application seems to follow either of two distinct approaches:
- a standard legend can be attatched to all sets of drawings that leave the...August 19, 2011, 02:40 PM
