[Revit Structure] - Improve Database info
This topic is closed.
    Applies to: - Revit Structure
    New Feature / Problem:
    To extend the available data in the database from a revit-model after export with the dbase-link tool.
    1) x,y,z (project and shared) coordinate from each element. Especially from structural foundations
    2) show more tables with data from analytical model categories(analytical beams, columns etc)
    3) to show the shared elevation-value from levels.
    4) to read if a lineload/pointload is hosted on a slab(like the table 'AreaLoadOnSlab'
    5) to see the parameter which shows if a element is flipped
    6) to read the structural settings, load combinations and load cases.
    1 and 2: to connect to calculations in ms excel.
    3) to link to a central database where the elevation from sealevel is specified
    4) for structural calculation purposes
    5) by example to see if a door or window is mirrored
    6) for structural calculation purposes
    Workflow:
    See above
    Benefits:
    See above
    Attachment comments:
