FBX Export with RPC - RPC's Huge in max
    I've exported my model to max for some testing and the RPC's are 12 times too big, they must have a diff. setting than the buildings(2 buldings are under all those cars and people Any Idea how to fix it?
    i think is related with feets that are 12 time bigger than inches (isn`t it?). max unit default sistem unit is inch and fbx unit is in feets. So try to change max sistem units in feets first, before importing to see what the result will be. Maybe it scaleing different archivision content.
      Try going into the 3ds max customize menu> units > system units >Feet
      When you import the fbx file, it should import at the right scale.
      Hope this helps
      Juan Carlos Moreno
      Sisley Cosmetics
        just curious question scott, if you exported rpc from revit to 3d studio max does rpc become realistic in vray rendering? (considering that archvision plugin for 3 max installed) i wish i was help like you scott gelped me before, but if i will answer i will say like gaby.
          I don't know anything about Max or Vray. I'm just trying to learn.
            I did verify it is a bug, known and its something in the FBX exporter. So its not an RPC issue.
              I think you also need the RPC plug-in for Max, which used to be free, but now costs around $250?
              Cliff B. Collins
              Registered Architect
              Autodesk Expert Elite
                If you have the all access pass its included.
