Hi, i am facing problem when i post wall sweep into wall in two direction i got stop symbol sometimes in other project and sometimes is not why it is behaving like that ?
why i can not insert wall sweep to wall sometimes ?
That looks like the edge of a wall. Wall sweeps only apply to the face of walls (either/both). To get it to turn back you'll need to edit the returns of the sweep.Greg McDowell Jr
about.me/GMcDowellJr
Don't use Modify Return on this one... Select the Sweep, you'll see two blue dots. Stretch those to meet in the corner and the sweep should close automatically.Martijn de Riet
All,
This one is throwing me for a loop, I have a simple wall with a mitered corner and a wall sweep on the top and bottom. Neither wall...May 25, 2017, 09:35 PM -
Hello, as you see in the attached image I want to make a wall sweep that runs twice around the head of the wall. For now, I can turn it only once ......February 24, 2012, 01:04 PM
I am not sure why this sometimes happens with wall sweeps. There are like, 6 nodes. I just want two so I can drag either end and have it stretch to to...December 11, 2017, 05:59 PM
I have a long thick wall with a few openings on it. I am trying to get the sweep to return inside the openings without breaking up the wall. I have tried...April 27, 2018, 09:04 PM
I made a rubber base (wall sweep) for my project and I want it on all the (interior) walls in my project. When i go to 'add walls' it will only place...May 8, 2019, 09:24 PM
