So I have been working a lot with title block families. Recently i've made a 30x42, 22x34 and am now working on a 8.5x11. The larger sheet files are pretty much the same, project based, stuff on the page, just different sizes.
My issue is this:
Is there a way to have a instance parameter that will allow you to modify text on a per instance basis?
This will be used for a RFI/Addendum view title. I need several instance based text boxes on the sheet. (REF sheet, RFI #, Issue Date) They don't need any sort of intelligence in the text box.
Similar topic here:
Predefined-values-in-new-sheets
My issue is this:
Similar topic here:
