unable to sretch height of doric column ?!!
    Why i am not able to make height of doric column reached to next level ?
    i tried change value of column height body into more values but nothing changed.
    the pogramme give me also top level :level2 but it did not reach to this level
    why this happening ? and how i can deal with it ??
    Revit Arch 2013 Certified Professional
    Phlippines Revit User Group
    Architecture | Structure | MEP
    International Order Of DeMolay
      i want doric column for aesthetic purposes in the design the office gave it to me supposed to be doric only.(i was wishing i can give instance parameter to height parameter but there is no height parameter)to stretch it manually.
        As engel said, the family probably isnt constrained correctly. This is one of the reasons i always make sure my content is built in house. Hit Edit family and go look...
          Ahh ok i got what you want try this one.
          sample: DORIC.rfa
            @engel_hg
            Did you made it or is it with library of revit architecture ?
            @Aaron
            how this will be wrong. i did not made column it is made by autodesk in its library. so it constrained prbably should be done by= autodesk we trust autodesk in this right !
            all i did i made the top level :level2 and it did not reach to level 2 as i input it.
              i just made it. as show just add height parameters to your doric family but make sure all the grove are lock to each other. just check my sample family.
                ooops i can not check because i have revit 2011.
                  i just asked myself ,is it better that we add height parameter to existing family but i hope anyone tell me how especially this family that come with library is a group of nested family :capital-pedistal-column body.
                    ahh ok just check this one.
                    COLUMN DORIC.rfa
