Hi, i have problem that i established the baluster family on front elevation family. now when i loaded into project and give it this setting i end up with this rotation of pattern that supposed to be straight without this opposite turns, how i can fix that ?
Problem with baluster railing degree
Rotate the baluster in your Family...Martijn de Riet
You could try this:
go to plan view, select all refplanes, geometry, and so on.
Cut to clipboard, Paste from clipboard, rotate (without hitting the escape button). This should keep at least some of the constraints...
More dirty solution:
Save as Baluster_nested
Reopen original and delete all geometry.
Switch back to Baluster_nested
Load into original Baluster and rotate,
Tie parameters togetherMartijn de Riet
I'm trying to place a valve Family into my project but I can't get the valve to rotate to the right position. Is there a way to create a parameter inside...
January 4, 2016, 03:52 PM -
I am wondering if anyone has some thoughts about this baluster panel? I would rather use a Model Pattern for the welded wire mesh, but as far as I know...February 11, 2011, 09:48 PM
Here is an image showing the railing, and I want to be able to create a railing like this like lines on a basketball.
Possible? Other avenues?...-
August 27, 2012, 04:47 PM -
I know I saw a post explaining how to fix families that don't rotate when you hit the spacebar but I can't find it now.
August 28, 2012, 12:41 PM -
I have a detail of beam on top of the column and plate in between, I have to show connection detail. Everything is fine but when it comes to bolt, i cant...
February 23, 2016, 02:47 PM -
