Hey I need to put floor drains in this drawing, we had to turn of all floors, as again they only want plumbing. All the floor drain I am finding load or need a floor to locate, making it extremely hard to add to the exsiting pipe. Is there any easy way to do this or a way in general to hook the pipe up to the drain. Thanks for the help.
Floor Drain
Assuming it's a face based family. When you place it, select Place on face. If your floors are turned off, it will place it on the level. You can also try a work plane. I don't know what family you are using. If you have to, you can model a floor if it is a floor based family."Keeping my view range hopeful"
Open the family, and set it to be Work Plane based. If I'm not mistaking you can place it on a level now.Martijn de Riet
Hi everyone, this is my first time here. Well, basically I've been trying to place the floor drain on the floor (I have already switched to place on level)...
Channel: MEP - General
November 6, 2016, 01:21 AM -
I have a raised floor in my model and the floor hosts supply diffusers. On one of my plans I need to hide the floor diffusers, no problem. I hid them...October 20, 2014, 05:23 PM
I'm creating a new family and I need the default floor can be modifiable length and wide but when I load it into a project Revit says that can't make...
Channel: Structure - Family Creation
February 8, 2017, 02:06 AM -
I am trying to split and paint floor finishes and for some reason when I try to use the split faces command I am not able to select the floor because...March 14, 2014, 05:34 PM
This may need to be in the family section, not really sure..........
Anyway, how do you modify the 10'x10' floor in the family? I can't...March 25, 2011, 05:59 PM
