Hi there,
I want to make a family that contains text and a couple of lines.
When the family is loaded into a project;
- I need to be able to change the text as an instance. (so that a copy in the same view can contain other text).
- and i want to be able to change the length of the lines. (so the object will contain grip point that i can drag).
A line based family cannot have labels.(?right)
and a generetic model based family cannot contain ref planes.(?)
Still need to learn a lot. there could be a simple solution to this, than i just din't see it.
