Revit OpEd: Opening a New View
One feature of Revit that has been with us for a long time is also quite subtle. When you open a new floor plan view Revit will attempt to respect what you are currently looking at in a floor plan view. For example, if you zoom into look at a specific room or door family and then open a floor plan for another level, Revit will open the new view zoomed into the same area of the model (but on the other level). The key is the view can't already be open. I've posted a video to explain visually...
Click here to view the entire blog post.Tags: None
This is an echo of something I wrote in 2011....
If you are in a plan view, when you open a new floor plan view (any "plan" view)-
Channel: Blog Feeds
October 25, 2013, 11:15 PM -
I wrote THIS POST about Revit's behavior when you open a new view. There are times when you open a new view and Revit seems determined not to show you...
Channel: Blog Feeds
July 31, 2014, 05:15 PM -
I've run into an issue with 2014, where some of my views show no geometry when opened. It's there, but the view is panned away from where it was created....September 25, 2014, 01:43 PM
Hi all,
I have a floor plan that is apparently set to elevation of +20cm. In the elevation view the level line is not seen (Iguess I've deleted...January 12, 2015, 07:05 AM -
Is there any way to set a view's default view? It seems like this must have been answered at some point but I can't find it anywhere. When I open some...January 19, 2016, 12:52 PM
